Rustproofing chassis
Richard Lewis
Hi All
Returned to Z3 ownership after a 20 year gap ☺
wondered if anyone had experience using a rust proofing company - I’ve been speaking with one near Bristol about having either a Dinitrol or Lanoguard cover.
One is typically used for the underside of vehicles like Land Rover defenders.
My plan is to check the sills before and make sure they are in a good place.
Is it worth it? Working on the basis that some level of rust proofing on a 25 year old car is a good idea. Would welcome thoughts.
ExMX5owner
Staff member
Australian Zeds
Queensland, Australia
Hi All
I have always used Lano, down side is, it remains a bit sticky and collects grime, or sand on the beaches I used to drive my Toyota Surf over, That being said, my surf never yielded to rust.. Personally I have seen chassis shots of GB cars, and wonder why they are so corroded... ?, Gimme an Aussie Chassis with a UK low mileage engine,, Please....:)
andyglym
Hi All
If you can and have the space have a crack yourself, you'll know what's been done then. Whip the outer sills off and check the inner sills, remove any corrosion and treat with POR15, same process for the outer sills, if salvageable. Same applies to the rest of the underneath.
colb
Newport, South Wales,UK
Treated my Z3 to a pressure wash underneath years ago, pulled sills off and all wing liners, everything had a good clean, my inner and outer sills were pristine, low mileage car so that helped. On the Z3 when dry it was treated with lots of clear Waxoyl, sprayed on with their application trigger spray and hard to reach cavities I used their applicator extension. The rear of the outer sills got an application of black Waxoyl. This was all carried out about 10 years ago and its still in good condition, always Sorned over the Winters.
When I acquired my Z4 I jet washed the underside with wing liners removed and applied clear Waxoyl to all underside surfaces. I applied Lanoguard to a fellow members E89 Z4 and found it was far easier to apply than Waxoyl, its a lot thinner and covers very well. Downside is its recommended to reapply annually. We had enough left after completing his car and we used it to give my Z4 underside a spray, still had some left for topping up his during the year ahead. Smell from it hangs about a bit but soon dissipates just like Waxoyl does. Not had the car on the lift since to see what its holding up like so can't comment on that. The Z4 is used all year and lives outside.
For ease of application Lanoguard is easier than Waxoyl, with the Waxoyl you can thin it down by heating the can in boiling water which thins it and allows a better flow in a spray gun or their supplied applicator.
ChrisD
Evesham
M44
Lanoguard is easy to apply yourself, if so inclined. You can work the 'injector' tool behind the sill covers if you don't want to remove them.
I can't really say how effective it is - better than not doing it though.
Just spotted you’re in N. Lincs. where abouts?
