S50 condenser
swamper
Bacup
M
afternoon peeps im getting the parts together to do a full refurb on the aircon.
has anyone replaced this and does anyone know if the condenser is spercific to the S50?
the part numbers are difrent to other zeds..but how diffrent can they be?
has anyone found a place to source parts from?
ive found this place but they dont seem to do the condenser
http://www.hypershop.org/32-081997-012003-petrol-manualautomatic-rhd.html
AGT1953
Glasgow
Z3M
Hi,
Now my mate has just replaced his and found that there are a number of units specified for the vehicle (Z3M)
At the last count, prior to getting one to fit he had tried at least 3 others!
He is on this forum under the guise of "J90MUD" and it might be worth contacting him for more information.
I can supply direct contact details if you want.
He is on holiday in Scotland at the moment and is planning to call in to see me tomorrow.
Andy Thomlinson,
Glasgow.
Had a look on realoem.com, it states the part has been discontinued, you will be able to get yours refurbished though Wayne, it will look like new once done.
swamper
Bacup
M
hmmm id not thought of that Brian
swamper
Bacup
M
ive sent your mate a PM Andy ..lets see if he gets back to me..cheers
AGT1953
Glasgow
Z3M
Good enough,
He is on holiday until Wednesday coming, but if he calls in to see me tomorrow as planned I will let him know!
Regards,
Andy.
J90mud
Rossendale
z3m roadster
im here at last.
the specific rad for the z3m has been discontinued except at £560 from bmw
after market ones from behr are circa 180
contrary to popular stories it will not come out from below the car even with the under trays off.
you will need longer screws of the same size/type to fix it onto the water radiator as the new condensers are thicker.
a few pictures to follow
vetinari
HI
I have a 2001 3.0i and had the A/C emptied and refilled last week. The technician found a leak at the hose connection into the condenser ,
he fixed this by wire brushing a manky looking connection and replacing the O ring .
The A/C now works well , but the condenser fan , the big brute at the front of the cooling system which you see as you open the bonnet , doe not run.
I've checked all the fuses relays , etc . i would like to check I have power at the fan before dismantling the front end to pull the fan , but am not sure where the power connection is .
Legend has the power plug on the fan is hidden under the fan , but I have a hefty looking 3 wire connection on the Right side of the condenser which disappears under the plastic around the front end .. Unfortunately this needs a concert pianist with 15 inch multi jointed steel fingers to disconnect the two pieces , I'd like to be certain this really is the power feed to the fan before I risk serious harm to the wiring .
Any ideas please ?
Vetinari
