Scotch Locks
HornelZ3M
Raglan. South Wales
Z3M Roadster
I have today used 4 scotch locks to connect my angel eyes to the sidelights. My question is why are so many different car sites saying bad things about them, one site showed a scotch lock fitted and the next photo was the outcome, a burned out car.
Anyone know anything about them as Jonttt has them on his thread about his fitting of the projector lights. ;)
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
When I saw the this thread title, Paul. I thought that you had been caught drinking, piloting a canal barge up in the highlands!!! :))
Sandy
Jonttt
Liverpool (UK)
///M S54
I think the problem with scotch locks is when they are not fitted properly and they can cause a short circuit.
So long as they are fitted properly they are fine. They have been around for a least 20 years. Thats why I used them as they are ideal for connecting the angel eyes into the sidelights ie patching into an existing circuit.
I think there are various styles readily available now.
I am ultra paranoid when I use then that they are connected properly though.
stevie_a
Glasgow'ish
Scotch Locks are things of the divil...
They can so easy give a bad connection, also leaves an open ends for water to penetrate into
best thing is to solder joint and heat shrink it, will take a long to do as putting scotch locks on.
Jonttt
Liverpool (UK)
///M S54
I agree solder and shrink wrap is the best option but for quick fixes in hard to reach places (to get a soldering iron into) scotch locks have their place. I always wrap them in electrical tape as well.
TaffZee
Near Llangollen North Wales
Z4 3.0 SE
Scotch Locks Nasty little things, the problem with them is they allow the wires to corrode which will eventually lead to a loss of connection or even worse a short. My advice dont use them for long term connections. Better to use these (see link) for repairs and Solder & Shrink tube for mods:
http://www.ebay.co.uk/itm/50-x-Mixed-He ... 3f184d681b
B
badman gee
ok for a temp fix, but not permanent.
i know a bit about cable terminations.
HornelZ3M
Raglan. South Wales
Z3M Roadster
Thanks guys, i thought there would be different views on them, as i have seen on other froums, they are not very well supported.
I have put them on with care and wrapped them in quality electrical black tape and look ok. I will keep an eye on them.
Thanks Jontt for the thread on fitting them, made the job easier. :ymapplause:
