Z
zedonist
Has anyone done the shifter bushing overhaul, any advice (including grammar), parts required etc?
Thanks for the links, I had seen the pelican how too. I don't think it is the pins, as the box I'd like silk in all gears, just play in the shifter itself.Here's a DIY for the bushings...
http://www.pelicanparts.com/bmw/techarticles/E36-Shift_Bushings/E36-Shift_Bushings.htm
But it could be the pins...
http://forums.bimmerforums.com/forum/showthread.php?1931950-2000-M-roadster-shift-pins
http://webspace.ringling.edu/~dplassma/bmw_diy/shift_pins/shift_pins.html
http://www.bimmerdiffs.com/collecti...s/bmw-zf-s5d-320z-shift-pin-service-parts-kit
My other Zed suffers with this. The gear stick tends to lean towards 5th gear until the box is warm.
