Slow windows
Z3Mroadster
How fix.slow windows?
Only grease,or need new pivot clips?
What is best grease for this?
I read that lubrication is not a long term solution because it attracts dirt.
Correct?
Thanks!
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Put a little silicon spray on the window rubbers, especially the vertical one
Grenville
Australian Zeds
Stanthorpe, Queensland.
Definitely silicon spray, not WD40 or RP7 or any other cat piddle --- they all eat rubber. And grease gets dirt in it and creates a sanding paste.
Yep agree, silicon spray, do mine fairly regularly :thumbsup:
Do I need remove door panel?
Personally I don't, I don't remove my door cards unless I really have too, too easy to damage them, I just drop the window and spray the runner where I can then put the window up and down a few times, others may do it differently, if they are really sticky do it a few times in a week.
That’s the best way, keep spraying as the glass goes up and down. No need to remove any trim.
Tony
Grenville
Australian Zeds
Should really only have to spray with silicon spray once or twice. It's as if the stuff was designed specifically for car windows.
As you like :thumbsup:
2.2 & 3.0 Sport
+1 for the silicon spray:thumbsup:
I have only sprayed mine once in 11 years.
Quite possibly because you actually use your car regularly Mike. Keeps things moving.
