RobSimsy33
- Aug 13, 2024
Hi, I'm currently restoring and engine swapping my 97' 1.9. I'm swapping the M52B28 Engine in from a donor Widebody Z3.
My question is that I'm attempting to use the rear diff from the 2.8 Widebody as it is a LSD however I've noticed that it is a slightly larger case compared to the 1.9 assuming that im going to need slightly smaller driveshafts in length but larger diameter at the differential end. Is there a work around for this?
I have read about E30 driveshaft however no clear cut conclusion.
Thanks in advance
Thanks in advance
