Hello Help needed Z3M
Speedo worked perfectly before winter lay up.
Went out in it last week and it was intermittent / kept stopping altogether then finally flicked up and down a few times now dead. No movement at all
Done cluster test and everything including speedo work.All other gauges are operating as normal
Changed speedo sensor on Diff today , still dead.
Pulled out 3 relevant fuses OK.
Removed cluster and reseated connectors.
All seem ok but nothing .
What else should I check and how ,
Could it still be a cluster fault even though speedo does not work when driving?
Any ideas
Any ideas
