strange temp gauge?
robertjones
Noticed on my z, the temp gauge moves up to the halfway mark after maybe, half a mile of setting off from home , even though the engine hasnt warmed up, it then stays there however fari travel, uses no water and fan kicks in o.k. , doesnt seem to overheat Is this normal ? As my last z would run for quite a while until the engine warmed up before moving to normal, engine is 1.9i
Robert,
If it aint broke don't fix it :), the temp gauge is a buffered gauge so when the needle sits in the middle it will cover a range of 20 or so degrees.
Brian
robertjones
Agree with u but just think its unusual and wondered if anyone elses z was the same , as I have never had a gauge that worked llke that before as soon as I leave the house the temp starts showing a reading
Brian4
Near Grantham
Z3 3.0i Auto
Same in ours gauge quickly to mid point and heater blows warm air about 5 mins later.
Mine does the same as Gaz and Brian's cars. I've had it over 4years now and it's never been any different.
As Brian H said and I agree.
Brian4
Near Grantham
Z3 3.0i Auto
Just looking on the wiring diagram for the Z3 and the coolant temp sensor for the gauge is at the rear of the cylinder head under the inlet manifold so it will get to see any heat pretty quickly perhaps that is why is rises fast initially. It also feeds through the DME control unit and this gives the analogue output to the temp gauge. Electronic wizardry so the likes of most of us cannot understand.
Gone are the days when one sensor is connected directly to the display for that item.
The speedo isn't driven by the gearbox but by the wheel speed sensors used by the ABS and AST or DSC and a sensor in the rear axle.
Z
zedonist
Anyone had intermittent temp gauge problem? Works normally or not at all? JIM
I've found mine does not work when i switch the engine off, it works again when i switch it on, must be an intermittent design fault.:woot:
Speedo cables are long gone Brian, except if the elastic has gone in them.:ymdevil:=))=))
robertjones
Blimey, no wonder it goes up so quickly!
Z
zedonist
Just a clarification the speedo is controlled by a fan disc and sensor in the differential only, the wheels spin at different speeds at different times during driving so would not be much use to the speedo.
jonco
Chester
'98 1.9 Auto
Robert,
Brian
Agreed - if you have access to INPA - engine module you can see the temp readout varying by ~10 degrees as stat controls even though instrument cluster temp guage remains steady. Maybe stat was faulty on previous Zed hence slow warm-up.
Problems in the bedroom department Jim?.......;)
Nothing a couple of tongue depressors and elastic bands can't overcome. It's the slivers that are the problem but I think if I use sandwich wrap first should be a go!! What are you using?
Thanks, I didn't get any owner manuals with the car. I'll see if that works now that you've cleared that up. JIM
Z
zedonist
It's still intermittent Jim, as I say, but I will sort it out soon.......let you know the solution in another three years......
vintage42
... the temp gauge is a buffered gauge so when the needle sits in the middle it will cover a range of 20 or so degrees...
More than that. The needle reaches vertical resting point at 155F and stays there until 205F, the highest I have seen my 1.9's temperature go on the ScanGauge sitting in traffic on a hot day.
http://i49.photobucket.com/albums/f280/vintagefortytwo/BMW Z3 Related/ScanGauge/ScanGaugeOn_zps0ee4d6bf.jpg
My (one electric) fan turns on shortly after 200F, so I have never seen at what temperature the needle might go past the vertical toward the red.
The needle stays vertical throughout a wide operating temperature range, even as the ScanGauge shows the actual temperature varying constantly with driving conditions.
