Trying to make sense of how it fits and where it seals.
The new roof from the donor car had an extra drain system below the bolts on the inside, but you need two holes through the bodywork which is going to be impossible to do. so assuming this was a later mod, going to leave it off .
The car is now all cleaned and ready
but I have an issue with the plastic surround part…
its not stuck to the side very well…
So I am not sure whether to remove it completely And then clean it all and reseal it.
it would appear that there should be a butyl strip either side of the plastic surround but not sure if everything stuck on the roof and then fit it , or just stick the surround part to the roof and put the other butyl strip on to the car and then install the roof….
grateful for any info on this from anyone that has done a roof swap
ta
ta
