the project I said I would never do when i bought it project
Monkey
When i bought the Z3, i said i wasnt going to do anything to it, apart from general maintenence.
that has now all changed.
Spec when bought:
1.9 Z3. Built March 1998 in Boston Green
Photo of when i bought it
Roof up
Roof Down
when i bought it, the list contained only
New boot lid to remove the luggage rack
New h/U as the car did have one
fix central/remote locking
fix electric seats
Electric seats were taken apart, freed up, rocking mod added and re fitted. and all working
H/U bought, a lovly pioneer MP3 with integrated parrot Handsfree kit, awsome
Central/remote locking fixed
whilst doing all this i found an oil leak, which is comming from crank case. this is a problem, which i still havnt permanently fixed, i was and still am planning on finding another 1.9 engine to drop straight in, and then completly rebuild this one. i was expecting to pick up an enigine this weekend, but it had already sold. so i'm back on the look. i'm NOT going to put a different engine in.
i put the car on a computer, as i noticed a possible miss fire, but i couldnt be certian, it was intermittant at best. the computer showed a miss fire, along with some other stuff (CAS sensor issue) so i check HT leads and found one to be a bit worse for wear (cylinder 3) replaced the HT leads and all codes now gone. and it runs alot smoother.
i have replaced the boot lid, which i found to be a different green entirely GRRRR, but i also bought a new front passenger wing, a new passenger wing mirror (both being the correct colour) and a new gear knob.
i bought and fitted a windbreak, i forget which one, but i'm not that impressed with it.
i also this weekend removed the mud flaps, and changed the BMW centre caps for new ones.
photo of how it looks now
To do:
Friday it going to get the back end painted so it all matches
need to find a passenger headlight washer jet, as this is how it looks
i want to replace the steering wheel, with a smaller BMW one, but thats not urgent.
and then in 2 weeks it having a very special treat.
i will say that all i'm going to do, but i know it wont be.
Brian4
Near Grantham
Z3 3.0i Auto
Re: the project I said I would never do when i bought it pro
Hi monkey
Welcome and good to see another Zed being revived.
Quarry motors are a good supply of parts for the headlamp washer or one of the breakers search engines(24/7 spares etc).
Happy hunting and hope to see you at Silverstone in July
Brian
Jonttt
Liverpool (UK)
///M S54
Which smaller BMW sterring wheel are you going to change it for as the newer ones will not fit and have non compatable airbag electrics ?
Snoops
Red Rose Country
Good to see another Boston green being given a new lease of life - top job :-bd
The bug gets to you eventually!
I've never mod'ed a car before I owned my Z3. It all started with a couple of tweaks....
Monkey
Brian4 said:
Hi monkey
Brian
cheers for the welcome, i'll look up Quarry Motors cheers for that. I've had bad experiences with the 24/7 find-a-part type places before, so i'd rather not use them.
not too sure yet, i dont even know which wheels are smaller. but changing the electrics wont be a problem.
hard top said:
Nice work Monkey, like the pepper pots, not many people would run with those nowadays bit I kind of like them.
I hope you know that you can buy plugs for your boot lid if you remove the rack?
http://bmwfans.info/parts/catalog/Z3/Ro ... r_rack_z3/
Thanks, i didnt like the pepperpots that much, but they are growing on me. And as no one else likes them they are "rarer" thus my car looks different. thats the idea anyway. yes i saw the boot plugs, but i dont like that look. one thing you will notice is that when i do anything i'll do it the "best" way, no short cuts. if it costs more to do, i'll wait till i can afford to.
i've owned lots of car, and mod'ed most, but the Z3 was not going to have any work done, apart from the essentials to keep it on the road, and legal. but i have wanted a project car for a while. and the Z3 is a much better car than i thought and i have grown to love it. and one thing after another and i'm here replying to this thread.
Jonttt
Liverpool (UK)
///M S54
Its not that simple I'm afraid as it would mean changing the "brain" of the SRS system. Later cars have a more sophisticated dual stage system which means that timing is an important factor in the way an aurbag is deployed, hence a later dual stage airbag wheel cannot be fitted to a single stage system car such as yours.
Some have fittd non airbag wheels but that depends how much you value your face and your insurance company accepting the much higher extra risk of personal injury without an airbag fitted ;-)
The only known option of fitting a smaller wheel whilst retaining an airbag in a single stage car such as yours is the raid wheels. Unfortunately these are predominently made for Porsches and hence are not cheap !
