- Dec 8, 2011
Just a short list of things to consider to improve the standard engine. Some are impractical without spending big bucks, some are easy to do, some are free (but they will all affect each other)...
Add a scoop to the air intake. This will have to be carefully designed and monitored to ensure the engine doesn't go "over-lean" at high speed.
Less restrictive air filtration.
Intake system should be heat shielded to reduce the effects of under-bonnet heat transfer.
6x MAF instead of 1.
2 plenums instead of 1.
Intake tract tuned to a speed the engine can attain (eg 6500rpm).
Throttle plate and shaft cross-section could be reduced more and the throttle plate leading and trailing edges chamfered.
Thermally isolate the throttle bodies from the cylinder head.
ECU that corrects fuelling for each of the cylinders, not just for each bank (1-2-3 & 4-5-6).
Improve the cylinder head. It's already very good, but not excellent. Minimum cross-section is 333 sq mm at the valve stem.
Inlet valve should be confirmed to have square edge profile.
Inlet valve stem could be reduced.
Inlet valves and springs could be lightened.
Exhaust valve should be confirmed to have a rounded edge profile.
Exhaust valve stem diameter could be reduced.
Exhaust valves and springs could be lightened.
Camshaft is ok.
Piston weight can be reduced.
Con-rods can be lightened.
Piston/con-rod/caps can be balanced to better than the current +/- 4g.
More heat shielding around the exhaust headers and possibly add a fan (or ducting) to blow the hot air under the car in a controlled way.
Exhaust header entrance area increased and a step created.
Exhaust header length and diameter tuned to a speed the engine can attain (eg 6500rpm).
Exhaust collector tuned to a speed the engine can attain (eg 6500rpm).
The diameter of the exhaust pipe is very close to optimal.
It's very difficult (nigh on impossible) to optimise the exhaust length because of catalytic convertor and muffler. The wave created by the closing of the exhaust valve is seriously corrupted by the cat and the muffler, as is the wave from the tail-pipe.
The crushed section of the exhaust muffler pipe should be replaced with a pipe of the same cross-sectional area of the rest of the system.
Muffler should be de-restricted.
Tail-pipe should be opened up. The current tail-pipe has a reducer down to 40mm.
Camshaft is ok.
