Third brake light.
Mattz
Hi everyone. I was replacing the gasket on this and on taking it apart I found that the assembly needs replacing. Water has gotten in and the whole thing has rusted. As I was retightening the two pieces back together one of the screws went straight through the black housing. The assembly if original is twenty years old now so I’m not surprised, but I now have a properly leaky boot.
Where’s the best place to buy one of these assemblies ?
spurs fan in a coupe
Is this the sort of thing you need? I have loads of high level brake light spares. I have better red lens too, the one in pictures is cracked
Mattz
Hi. Thanks for getting back. I have the lens wrapped, so would like to keep that but I need the rest of the pieces. So the holder and the circuit board.
I can’t take the plug out either. Does it just pull out ?
@spurs fan in a coupe
Mattz
Is this the sort of thing you need? I have loads of high level brake light spares. I have better red lens too, the one in pictures is cracked View attachment 74074View attachment 74075View attachment 74076View attachment 74077
Hi spurs fan ! Don’t know if my reply got to you. I would like everything but the lens as I have that with a wrap on it. I need the circuit board as well as this is badly corroded. Does the plug just pull out ? Mine seems jammed and I don’t want to force it.
