Z3. Rear trailing arm. Y'know that plate that the coil spring stands on. In the middle of the plate there's that raised bit that the spring sits round.
Sorry. I shoulda taken a picture but I'm sure you know what I mean.
Well. That raised bit on mine has a hole rusted in the side of it.
I could weld a patch on it but the whole raised lump is quite rusty so probably very thin. So (this is the long shot) is there a repair patch available? Grind the old plate off, drill out the spot welds etc and weld on a new plate?
Or any other suggestions which doesn't involve replacing the whole arm?
