Thread direction on thermostatic fan?
Paul Weller
Hayling Island
Roadster 1.9i 140bhp
Hi All
I am in the middle of changing the water pump/ radiator and thermostat on my M44 Z3. I have the thermostat off and radiator out, as well as the fan blade.
The nut for the fan thermostat on the water pump shaft won't budge!
Before I force it, I thought I should check if anyone knows if the thread direction is normal or Left Hand?
Paul
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Left hand thread I think
jonco
Chester
'98 1.9 Auto
Fan assembly is left hand as others have said - pic of removed - you should be able to see thread direction.
Brian4
Near Grantham
Z3 3.0i Auto
Yes definitely a left had thread.
Brian4
Near Grantham
Z3 3.0i Auto
Big adjustable and a sharp tap to the right standing at the front of the car.
opposite to the old saying ' righty tighty lefty loosey'
Mazza
Bognor Regis
Just seen this thread Paul,
If you ever need them, I have the long 32mm spanner and the one that holds and locks the pulley. For removing the fan assembly complete.
Paul Weller
Hayling Island
I will know by mid morning if I need to take up your offer Malc. Will keep you posted, thanks
Paul
Paul Weller
Hayling Island
All undone! I used my cutter change lever from an angle grinder to pass over a nut and use as a lever. Now just waiting for the new pump to get delivered today before it all gets put back. Nothing was obviously wrong with the thermostat or pump, and looks like they were changed in 2007/08 from the date stamps. Radiator was original so I am hoping changing that will make the difference!
Mazza
Bognor Regis
Fingers crossed !!!
Stevo7682
Maybole , South Ayrshire
If you ever come across a viscous that is solid and just won't crack off.
Came across this video ages ago and saved it.
Thought I'd try it when doing the cylinder head job on Lynne's zed and worked no problem at all.
View: https://youtu.be/MqnYrIpih2I
Mazza
Bognor Regis
That is really clever, but you need to take a few bits off first.
With the ‘special’ tools that I have, you can remove the fan with everything else in place :)
gookah
Shropshire
2.8 Z3
Wow, I will be using that method from now on
Stevo7682
You can still do it with all in place he had stripped off a lot on his vid .
I done it on Lynne's with only belt removed
Stevo7682
Works really well as the belt fitted as shown locks it all down and let's you get a bit of push on the spanner without any slippage of the pulleys
Mazza
Bognor Regis
I stand corrected .......:thumbsup:
