Tip of the day..
Southernboy
See more from SKF
Vehicles make many sounds. Most are normal while the vehicle is in motion. But there are times when a noise coming from under the car can be a serious matter. Here are a few common “noises” that may come from the rear axle that need immediate attention:
• A “whirring” noise while decelerating at any or all speeds is most likely caused by bad pinion bearings or loose pinion bearing preload. This condition is typically always diagnosed as a bad ring and Pinion gear.
• A “howl or whine” during acceleration over a small or large speedrange is usually caused by worn ring and pinion gears or improper gear set up.
• “Rumbling or whirring” at speeds over 20 mph can be caused by worn carrier bearings. The noise may change while cornering or turning.
• Regular “clunking” or loud “clicking” every few feet may indicate a broken ring or pinion gear tooth.
• “Banging, clicking or clunking” while cornering can be caused by broken cornering gears commonly called “spider gears”, lack of sufficient positraction lubrication, or worn positraction clutches.
• A “Rumble” while cornering or turning may indicate bad wheel bearings.
• A steady vibration that increases with the vehicle’s speed can be caused by worn u-joints or an out of balance driveshaft.
• “Clunking or clicking” when starting to move or getting on and off the gas might be loose yokes, bad u-joints or worn transfer case or transmission parts.
All unusual or strange noises produced by the driveline while driving have a root cause and should be thoroughly investigated to prevent serious damage to the vehicle or the operator.
Ianmc
New Forest
Z3 (M44)
Whinging from the passenger when going around corners enthusiastically. Solution is to buy a Bond car to eject passenger.:)
2.2 & 3.0 Sport
...Whinging from the passenger when going around corners enthusiastically...
Did you get a bit of that this weekend Ian;)
Southernboy
I subscribe to a 4x4 forum where several members there have used Liqui Moly LM 47 MoS2 CV joint grease added to the diff oil.
They all claim it's a "wonder cure" for the whining diffs - front and back.
I have a very faint deceleration whine, so I may get a small tube of the stuff and add it to the diff. If it works - then great, if not, it's not a major to drain and re-fill. And for about $3.00 for a 100g tube - cheap enough.
Liqui Moly claim it can be added to transmissions and diffs to provide extra lubrication to the gear faces. It handles temperatures from -30 up to around 130 C.
I like a bit of diff whine - reminds me that I’m driving a proper car (aka a dinosaur!)
It’s why BMW engineered it into the Z3 say.
