TYRE SIZE
mandy dougan
RETFORD NOTTINGHAMSHIRE
3.0i
hi ive just , my first bmw z4 3.0i on an 04 plate (photo to follow). Sadly I have a problem, I think it has the wrong sized wheels on.So can some one tell me what the correct wheel size is please. Mine tyre size is 245/40R18.
andyglym
:welcome: to the forum from West Cumbria. @t-tony has the same car I believe so may be able to advise.
ten staggared
18s are normal for z4, 245 is the width of the tyre, they are often staggered meaning the fronts may have 225 width tyres, I had z4 wheels style 108 with the above set up so yours may well be perfectly normal
mandy dougan
3.0i
Thanks for your swift assistance. The problem is i think they are rubbing when going aroung corners etc the just doesnt seem yo be enough room for the tyre to turn smoothly although it has just passed it MOT
I will post pict tomorrow of my new pride and joy
Are the fronts 245 if so that might be the issue and are the fronts rubbing, it would help if you post a pic of your wheels, someone on here will know what tyres they should have on
Is it possible that someone has fitted the rear wheels on the front? OR has had the wheels split and has built them together incorrectly?
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Has the car suspension been lowered and has the car had spacers fitted?
It really depends what was specified at new purchase and if the wheels have been changed since.
Here's the options as new
mandy dougan
3.0i
18 inch staggered set up should be 8J - 225/40/18 front 8.5J - 255/35/18 rear you need to check the tyre size on your car front and rear. As said if 255s are on the front that's probably the problem, assuming the wheels are standard.
I have 245 on front and 245 on rear!
I would say that is incorrect for both front and back, but depending what size wheels you have, the wheel width will be stamped on the inside of the wheels, when you take it to the garage ask them to check, if they are staggered the wider wheels should be on the rear and the tyre sizes should be as I quoted. If the wheels are the same width (square set up) but 18inch then I would suggest they are incorrect for that car (unless someone can advise otherwise) as the square set up should be 17inch wheels (width 8J all round) If you go to a decent independent tyre outlet they will advise you.
Hope that makes sense
Redline
Nuneaton
E89 20i msport
Potentially one of two problems.
I suspect that someone has taken square set up MV2s off another car. I believe they were fitted to other BMWs in square set up (same width all round).
It's the width and the relevant offset that determines how the wheels fit in the wheel arches. You may have to fit different wheels, but first determine the size wheels and their respective offsets are and then you can use an online checker to see how those tyres/wheels impact the critical edges of the tyre. You can then see where the potential for rubbing occurs. That is all something that your local garage can do.
It is possible however that someone has instead squeezed the same size tyres on all four wheels (8J front and 8.5J rear). The pictures don't seem to show that might be the case, but worth checking. That is problematic in that if they have the same aspect ratio then two of the tyres (if not all) will have the wrong diameter and hence rolling circumference. That can affect the handling and even the drive train because of incorrect gearing. Consequently, your speedo may also be incorrect.
Need to establish exactly what wheels and tyres you have on the car. :thumbsup:
mandy dougan
3.0i
mandy dougan
3.0i
Thank you. I will post when i get things sorted
So you people have been great with my present problem, epic fail on my part wantin a Z4 3.0 . trotting off to buy one on my own like a "big girl" after splitting with hubster. My chin is up and I am positive these problems can be rectified I am sure, I will keep you all informed when to problem has been looked at. This girl will not be beaten
