- Jan 18, 2020
- Model of Z
- 4 2.5i
As I have comes across this problem, I thought I would share just in case others are unfortunate.
Few weeks back the passenger airbag warning light showed a fault on the dash. I tried to research the problem but nothing was obvious. Maybe an isolator switch in the cabin but nothing. Does the system require resetting again was unsure. As nothing was coming to light I decided to take to my local garage where the car has been going for the last 4 yrs. after a day with them they came back with answer of the connector had water in and therefore caused a short ( £280 + vat . Before they where going to install they needed to find the root to the leak. The garage rang back and explained there was an inch of water in the cab the carpet was soaking this would have caused the part to fail.
They told me the actual leak came in from the windscreen, the scuttle board was defective therefore let water in underneath the windscreen. New scuttleboard ( £160 + vat ).
Once the leak and the carpet has been reinstalled then the connector will be fitted. The airbag connector has to be reset by BMW.
I hope this helps others if they should come across this.
