- Oct 13, 2017
- Location
- Llandrindod Wells, Powys
- Model of Z
- Z4 SDrive 23i M Sport 2.5Ltr. H.T Convertable
After getting the Zed through the M.O.T. I started to have a look around the engine bay to see if there was anything else I could do to smarten it up. While having a poke and a prod I noticed that there was a noise coming from the front of the engine. It's hard to describe, not quite a squeal and not quite a rattle, but a bit of both! I am thinking it is possibly the water pump. The temperature is stable, the Zed it running well, and the noise seems to disappear when revs are increased. However, I have only just noticed it so perhaps, if it is the pump, it is only just beginning to fail.
I have never replaced a pump on a Zed, so:
1. Can it be done from above?
2. If not, has anyone replaced one and if so are there any tips?
3. As I'm now starting to feel my age and do not really fancy crawling under the car like I used to, is there anyone out there in Zed land that would be willing and able to do it for me? ( I don't really have any indy garages around here that I would trust to work on the Zed)
4. If 1 above applies, then forget 3, but 2 still applies for the tips!
5. If 3 applies, I don't mind traveling as long as there is a good hostelry nearby that can put up me and the dog if needed!!
Colin.
Colin.
