can any one tell me that has a 1.9 Z3 after you have been for a run and car is up to normal working temperature dose the hose from bottom of radiator to thermostat still feel cold and the one from the engine back to top of radiator feel to hot to hold. My reason for asking is my hoses are like this I had to call RAC out yesterday as I had a water problem he felt theses pipes and said they should be same temperature and felt it was thermostat not opening causing a circulatory problem.
Ok I thought I know I replaced this along with water pump just over a year ago when I got the car but things can pack up so I drained the whole system down replaced with another new thermostat ( I did test the one that came out which worked ) I’ve flushed every pipe through blocking off various pipes to make sure all have water circulating I’ve taken out and checked pump that is ok looks as good as when I fitted it a year ago. I flushed the heater out and have checked that the heater valve operates properly while off that’s ok. I’ve flushed the radiator through and back flushed it.
I have now refilled with water and anti-freeze bleed the system while doing it left car running until up to temperature heater works great so I know there’s no air lock there but this bottom radiator hose is still cold. Problem I have is I don’t know if it’s always been like this as I’ve never really had cause until now to feel them as all has been ok.
So just nip out and have a feel please and let me know.
