Your both right thanks, just popped out to the Zed Den and sure enough a hole on the side of the battery. These Germans think of everythinkThere may be a hole in the end of the battery casing to plug the 90deg connector into. You may have to remove a cap first. The other end of the tube should be through the floor to vent the gasses outside the car.
Is it just Bosch that have this?There may be a hole in the end of the battery casing to plug the 90deg connector into.
That makes sense, thought it was that at the time.All cars where they have the battery sited in the boot
The OEM batteries have them and so does my Duracell.Is it just Bosch that have this?
Never seen it on any other car before I got the Z.
