Thank you!Easy to remove the bottle, disconnect the pump connector and the 2 (if I remember rightly) 10mm bolts and it pulls out. Then get some Milton in there and leave it soaking for a while, empty, rinse and put it back in the car.
E85 removal is different .. but Milton fluid is a good shout.. give it a scrub with a brush if you can and remove the scummy fluid after .. refillEasy to remove the bottle, disconnect the pump connector and the 2 (if I remember rightly) 10mm bolts and it pulls out. Then get some Milton in there and leave it soaking for a while, empty, rinse and put it back in the car.
