Wheel spacers.
Philip unsworth
Hi guys need some help I'm looking a getting some wheel spacers for my z3 2.8 wide body running on standard suspension and stock 17 inch wheels what would be the best ones to get thinking of 20mm for the back but what would you guys recommend?
You really need to measure up and see what your car needs (wheel width, tyres profile, height of suspension all plays a part and of course how you want it to look).
I’ve run from 12-25mm depending on what wheels /ride height it’s running.
Which wheels are your running and is it lowered?
mwpe
Camberley
With stock suspension and OEM 17 inch wheels, 20 mm is just about right.
Philip unsworth
Thanks for the reply it's running standard suspension and not to sure what wheels they are
On my Z3 I had staggered wheel set up and used 20mm on the rears and 14mm on the fronts. Those same spacers now live on my Z4.
2.2 & 3.0 Sport
Mine are both Sports models but and 17 inch rims. I run 20mm on the rear, none on the front.:thumbsup:
From hour pic looks like your are running the original 16inch Zstar alloys.
Those could do with 25mm on the rear.
Probably 10 on the front.
This clip shows how to measure
View: https://youtu.be/3LeFZsyGRrs
ALWAYS get hunbcentric ones. I believe the hubcentric are at least 10mm upwards as the lip on the standard hub is 10mm so it must be at least the same or more to clear it (hub centric ones have their own lip just like the standard hub, don’t go for flat universal ones.
Smallest I’ve used is 12mm
Plenty on eBay (search e36)
top tip - remember they will come with longer wheel bolts - don’t confuse the bolts - as k me how I know (put a longer bolt on and didn’t have the spacer fitted :facepalm:
Philip unsworth
Thanks for the reply I'm using a stud convertion kit so dont need the longer wheel bolts because I know I would end up doing the same thing lol
iv put 20mm on the back of my wide body not the one in the pic just cant decide what size spacers I want for the front what would you recommend I was thinking 10mm
Had 14mm on the front of my Z3 (none ///M) and they're now on my Z4.
I did Carl,
Feels like forever mate.
