Wheel spacers
Addison1967
Hi thinking of putting wheel spacers on 20mm rear and 15mm front on my z4 03. 2.5 roadster 18in rims 8 on front and 8.5 rear. Will these fit ok. All new to me a bit clueless. Thanks
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
Should be fine if the 18" wheels have the same off set as 108 s. Other people on here have that set up.
Exactly what I have on my Z4 with staggered 108 style wheels.
By the way welcome from me near Lincoln.
Yes, exactly what you asked about. Had the spacers on my Z3 before this car. Where are you located please?
Thank you, not thar far from me. There are several members in your area too. There used to be a members map on here but it was lost on the recent software update. Shame really.
No not really mate. I brought mine home from Florida one time, I got them off eBay USA. Just make sure to get “hub centric” ones with required longer bolts.
These are roughly what I paid for mine Neil.
For some reason the 15mm ones are slightly more than the 20mm, was the case when I got mine though,
That would sound about right, it may tell you on the eBay listings, I didn't check tbh but they will send the correct ones for each size of spacer.
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
Like Tony said, you should get the correct bolts with the spacers, but 50 and 45 mm sounds right.
