This morning I tried to use this. The wipers went back and forth and the headlight spray worked but no windscreen spray.
I just went and looked it and fiddled with two pumps by jiggling them a bit. Now neither the headlight spray or the windscreen spray works although the wipers still go back and forth a few times.
Now I have discovered that the same genius at BMW who decided headlight globes were easiest to replace through the wheel well put the fuse box behind the glove box where it will be easiest to check on lonely stretch of road on a dark wet night. Not.
On the washers any ideas?
