Hi all,
I've bought myself a dashcam for the Zed and want to wire it in permanently. I've bought myself a 12V-5V DC/DC converter for a couple'a quid, and an add-a-fuse from eBay. The install and wiring is no problem to me, the only issue I have at the minute is getting a wire through the firewall.
I looked around the fusebox and under it, but I can't see where the loom goes through the firewall. The fusebox looks pretty deep/tall, and I'm guessing the loom goes through the firewall somewhere inside this box and through to behind the glovebox. Would I be correct in assuming this, and if so, how can I get access?
Alternatively, are there any fuses located inside the cabin that I could use instead?
Cheers folks,
Forsh
Cheers folks,
Forsh
