Z3 2.2i 2002 relatively low mileage.
Gordy
Spanish Costa Blanca
Z3 2.2i
On start up particularly, I can hear a ticking noise. In the old days I would have said: "Tappets need adjusting". But not with this engine? Does anyone have any suggestions and should I be worried.
Many thanks in advance,
Gordy.
Hydraulic lifters most likely the issue, if it does not clear when warmed up or after driving there may be other issues.
worth a read.
Lifter Tick (solved)
Gordy
Z3 2.2i
Gordy.
worth a read.
Before you grab the spanners try an engine flush, STP or Wynns for example and an oil change, could be a lifter with a blocked oil way etc.
Try cheap first ;)
And probably 1 or 2 that are faulty. Engine oil with flush first, then new oil and filter.
