It's the lower part of the mirror that is damaged, the bit the ball joins fits into - at the moment I have it gaffered and it is working fine - just looks horrible, can't go to Gaydon with it looking like it does - thanks for info re emailHi @Anthony
Just to let you know I've removed your email from the post, otherwise they can end up being scraped and added to spam lists. Anyone can use the Quote in Conversation button to message you directly
Out of interest, what is wrong with your existing one as some internal parts are available - it's just the plastic casing which isn't!
You may want to have a look at this thread and the link contained in it. If the casing is ok you can replace the rest with this. @TaffZee just did it with his.It's the lower part of the mirror that is damaged, the bit the ball joins fits into - at the moment I have it gaffered and it is working fine - just looks horrible, can't go to Gaydon with it looking like it does - thanks for info re email
Thanks - it sounds as though it's the spacer block that is the problemYou may want to have a look at this thread and the link contained in it. If the casing is ok you can replace the rest with this. @TaffZee just did it with his.
https://zroadster.org/threads/at-last-a-cheap-easy-fix-for-broken-bmw-z3-door-mirrors.4901/
