One of the lights for our heater controls has failed but I cannot see how the bulb comes out. I have gained access to the rear of the heater controls and found the bulb, I can remove the wiring but not sure if the bulb pulls out or twists out? Can any body help please.
I've mended the light in the heated seat switch. It must have been a loose connection because when I pushed the connector back on the switch after I pulled it out the lights work now.
I'm working my way through the little niggles.
Brian
Brian
