Dado
- Dec 25, 2017
- Model of Z
- 2.2 mtec
Hi guys
Has anyone else had a problem with their indicator stalk?
It works perfectly on right signals switches off when turned straight as it should, but on a left turn the stalk clicks back when straight only for the indicators to carry on flashing, the annoying thing is it does'nt do it every time, its about a 50/50 split whether it stops or not.
When it stays on it takes a lot of flicking up and down on the stalk to get it to stop and if turned off manually the chances of it stopping are even greater, it's done this since pretty much since I've had the car (3 years) but seems worse lately.
I had the wheel off recently (will post some pictures of re-covered wheel soon) and took the opportunity to remove the indicator stalk assembly but could'nt see an easy way into the mechanism so gave it all a squirt of switch cleaner and replaced it, but no difference.
Any ideas other than replacement?
