Hi, i've been working on my face lift Z3. I had to strip some of the car as i needed to fit a new lock actuator into the drivers door and cable for the fuel flap lock . I decided to rust proof it with some Bilt hamber wax whilst its stripped..... My question is about the outer sills.... The inner sills are basically rust free, so i've waxed those inside and out.....The outer removable sill panels whilst very good, have some mild corrosion on the unexposed side under the surface at each end. My plan is to sand them back, use some bilt hamber gel to remove the corrision as much as possible, then apply some rust converter and an epoxy paint.
Should this sort them out or am i better off just fitting new panels? This car is a keeper so looking to do the best for it long term.
Thanks for any advise.
