For Sale Z3 parts - lots!
Andyboy
SHEFFIELD
M43TU 99-2002:
Top hose £10
Upper timing cover £25
Flywheel £40
Driveshaft £40
Propshaft (manual) £35
LH engine mount arm £20
M44 96-99:
Cylinder head £100
Flywheel £40
OS trailing arm recon £180
Front undertray set £50
Exhaust manifold £50
Throttle body £20
M52 M54:
Genuine rear exhaust box £175
Top rad hose M52 M54 £20
Manifold lambda probes £15
ALL:
Steering rack £100
Towing eye covers £10 (black/silver/topaz/red)
F-R seat motors £25
Seat switches £15
Airbag modules £20
DSC ABS unit £60
Dash cluster various £35
LH mirror, black £65
B post top trim £10
NSF wing panel £35 (BLACK)
Front foglight trim £10
Rear caliper £25
Chromeline ashtray £10
Roof switch (late) £25
Spare wheel lift cord £15
ASC switch early £10
Front arch liner £20
Window switch £10
Wiper stalk £15
Body control module £20
Indicator stalk (non OBC) £20
Headlight aim switch £10
Interior chrome door handle £10
Gas boot struts £15
Interior puddle light £10
Dash centre air vent £14
Side air vent £10
Cruise control motor £30
Door striker catch £20
Blower fan £20
Passenger airbag £15
Master cylinder DSC £20
Master cylinder £20
DSC sensor (m/cyl) £10
Alarm module £10
Door check strap £14
Glovebox £15
Boot seal £15
Rear light (pre 99) £15
FACELIFT WIDE BODY
Rear NS wing £40
NSR trailing arm £175
DSC ABS pump £50
Driveshaft 2.0 2.2 £40
Heater facia panel £10
Mad2718
Doncaster
Hi Andy,
is the blower fan the heater blower?
cheers
Dave
Andyboy
SHEFFIELD
Yes.
Mad2718
Doncaster
In that case I will have it if it’s still available
Andyboy
SHEFFIELD
Make sure it’s the right one!
Andyboy
SHEFFIELD
Standard non air con type blower motor.
Mad2718
Doncaster
According to real Oem I need part number 64111373766
Not sure if yours is the same part number as can’t see it on the pics
Mad2718
Doncaster
The car I need it for is non air con so fingers crossed
Andyboy
SHEFFIELD
That's it, Bosch number 0130 110 130.
Andyboy
SHEFFIELD
Sorry, it's for an air con car.
Andyboy
SHEFFIELD
No problem. When do you want to come and collect it?
Andyboy
SHEFFIELD
M43TU MAF sold.
Percy
Hi Andy do you have an ariel the bottom bit. Inside the boot. My radio has stopped working. If so how much
cheers
Andyboy
SHEFFIELD
No sorry, only what’s on the list.
