Does anyone have a link to a full wiring circuit diagram for pre facelift Z3 ? In particular I'm looking for info for instrument lighting circuit. Thanks
Thank you Jason, much appreciatedcant remember where i got mine but i do have a pdf
There a quite a few different versions 4 or 5 IIRC, I just end up printing the section I need at the time.just a look at the cost of having some of these printed.
based on 5 copies, they end up about £18.50 plus postage.
10 copies £13.50 plus postage.
Royal Mail 2nd class post £3.00
Anyone interested in a group order?
A4
385 pages
coil bound
plastic covers.
A word of caution, the instrument cluster back lighting and centre console back lighting is controlled by a rheostat in the main lighting switch, these can blow quite easily which leaves you with no panel lights whatsoever.Does anyone have a link to a full wiring circuit diagram for pre facelift Z3 ? In particular I'm looking for info for instrument lighting circuit. Thanks
Battery is disconnected and I'm only doing 2 connections, so hopefully all will be goodA word of caution, the instrument cluster back lighting and centre console back lighting is controlled by a rheostat in the main lighting switch, these can blow quite easily which leaves you with no panel lights whatsoever.
