Z3M ABS issue
Z3Mroadster
Hello!
My ABS not working...
Error code 20:
ABS valve inlet front right
I was testing wheel sensors-all about 1000 ohm...
How test Abs pump solenoids resistance from switch?
I was only testing wheel sensors-all about 1000 ohm...
There are one red and one brown wire from ABS pump motor and 8 blue wires(i mean from ABS solenoids)...
Car is euro Z3M-S50B32
1997.
Z3Mroadster
Thanks mate!
Is okay try activate ABS pump motor with 12V when I disconnect ABS plug?
There are one red and one brown wire...
And 7-8 blue wires...
Also I noticed the brake pedal catch lower than usual...Sometimes brakes
immediately when I touch brake pedal...
Brake fluid is new...
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
I don't recommend playing with 12V DC and the wiring unless you know what you are doing.
Z3Mroadster
Problem is ABS solenoids...
ABS pump motor is okay(I am check with battery)...
How to fix.?
Althulas
Banburyshire
M Roadster
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
If you are playing with wires then I suggest that you get a copy of the wiring diagrams for your car. Read the first page to ensure that they cover the build date of your car. Link below.
http://wedophones.com/BMWManualsLead.htm
The front right has two (2) valves, an inlet and an outlet. The error code does not differentiate between them, so you'll need to check both.
Use an ohm meter to see if there is any major resistance difference (say, +/- 20%) between all the valves. This will tell you if the valve solenoid/coil is the fault e.g. High reading = lost its magnetic suck to work the valve plunger. Low reading = burnt out.
If you are using 12V DC, ensure that the supply is properly fused, so if there is a fault you don't get more smoke and flames than needed. Carefully apply the voltage to the connectors identified from the wiring diagrams and see if there is an audible click from the valve working.
Hope this helps
Murray
Z3Mroadster
Thanks guys :)
Vacuum lines is not potential problem?
My brake pedal sometimes catch lower than usual...
