Z3M exhaust
Medskipper
Z3M & Z3 1.9.
Does anyone have a schematic drawing of the exhaust system? Serial numbers will be a big help!
I have the Z3M 3.2. S50 engine. Year 2000.
I can’t seem to find anything on the Net!
many thanks for any help
Medskipper
Z3M & Z3 1.9.
Tried that! Doesn’t have a drawing!
it does know my car but no sign of drawings or part numbers
gookah
Shropshire
2.8 Z3
shows drawings and part numbers when I click the link?
Catalyst/lambda probe
Sponsored links
No.DescriptionSupp.Qty From Up To Part NumberPriceNotes
For vehicles with
Catalytic converter
=Yes
01RP-exhaust pipe catalytic converter118301404984$2511.00
02Hex nutM10418301317898$4.70
03Gasket Asbestos Free211621317264$18.37
Required for repair
--Hex nutM10418301317898$4.70
--Torx boltM10X45411621318568$4.30
04Torx boltM10X45411621318568$4.30
05WasherD=10MM407119904201$1.02
06Bracket118311401522$8.14
08Hex bolt with washerM8X20-U1-8.8207119904992$0.55
09Exhaust support118301404760$10.00
10Fillister-head screwM8X35-10.9-ZNS3207119906650$0.87
11Joint sleeveD=8MM418207546579$2.86
12Washer8,4X16X1,6-ZNNV207119907030
13Self-locking hex nutM8207129964655$0.25
13Self-locking hex nutM8-8-ZNS3207129904002$0.18
14Clamp lowerD=63,5MM118201404098$10.62
14Clamp upperD=63,5MM118201404099$10.62
15Hex boltM8X16107119913612$0.62
16Hex bolt with washerM8X20-U1-8.8107119904992$0.55
17Hex bolt with washerM8X45-8.8-ZNS3107119903931$0.71
21Flange218111719417$12.64
22Gasket ring118111723379$8.37
23Gasket ring118111723379$8.37
24Hex boltM8X55-8.8407119902957$5.27
25Hex nutM8 SW12411621744323$0.85
26Oxygen sensorBOSCH/L=1075MM111781406621$215.65
28Oxygen sensorBOSCH/L=935MM111781406622$215.65
Exhaust system, rear
Sponsored links
01Rear muffler left118101404317$787.88
02Rear muffler right118101404318$787.88
03Set of add-on parts, silencer118210151441$33.52ENDED
05Hex boltM8X55-8.8407119902957$5.27
06Hex nutM8 SW12411621744323$0.85
07Holder218212242792$8.88
08Rubber Ring218211105635$4.83
09Hex bolt with washerM8X20-U1-8.8207119904992$0.55
10Rubber Mounting418211704198$21.41
11Hex boltM8X45405/200207119900233$0.82ENDED
11Hex boltM8X45-8.8-ZNS3407119902955$0.62
12Hex nutM8-ZNS31207119904024$0.20
13Gasket ring218111723379$8.37
Notes
Medskipper
Z3M & Z3 1.9.
That’s great, many thanks.
As the prices are all in dollars, is this the drawing for the S52 Engine?
possibly the same as the S50?
it does look very much like mine as I was under the car this afternoon!
Barry
Pingu
Use the "Search Parts" links on here for accurate prices. You can buy from here, as well.
