- Feb 18, 2016
- Model of Z
- Z3M Imola and Z4 (e89)
For you Z3M owners. You may want to check under your intake manifolds, there are 2 rubber mounts attached to the intake and a Y bracket bolted to the engine supporting the intake, which is quite large on the M.
After stripping mine out to replace the vacuum pipes I discovered both were broken. Without these the weight and vibration of the manifold is taken by the inlet trumpets which are plastic and I assume could crack from weight and vibration.
New ones on the right of the photo.
