Hi all
Recently bought a 1998 Z3M roadster and trying to rectify a problem with the rear fog lights. As it is an 'M' front fogs aren't fitted. The original switch had been replaced by a rocker switch (latching type), and the rear fogs work ok. I found the original switch which had been left in the glove box and discovered one of the brass contacts had come adrift internally, which I fixed. However, it is a non-latching (momentary) switch, and when fitted the fogs only work if the button is held in.
So I guess the original relay just needs a momentary signal to make it latch on, and another to switch if off. RealOEM parts look up shows a 'control unit' at 3 times the price of a standard relay (part no 61356903410 ), so that indicates it is more than a simple relay.
My theory is the original relay is faulty and now only works when latched on by the rocker switch, or it has been swopped out for a standard relay.
Trouble is - I can't find it. I have looked at the various wiring diagrams but none quite exactly match the wire colours on my car. I think the rear fog light relay is K49 (and the front fog lights are relay K47 which is normally in the engine bay fuse box). One of the wiring diagrams shows K49 is located on a relay carrier under the dash, but the wiring colours and relay part numbers don't match my car.
Any help greatly appreciated....
Thanks
Kieran
Thanks
Kieran
