I looked at the oil level indicator last week and it was reading in the middle. Fine I thought.
After reading about propensity of the 3.0L engine to use oil at a vast rate of knots, I looked again to find it down to two. On Friday I was startled to find it down at one and started to worry a little, so, I bought two litres of oil. One to put in as soon as I got the warning came on and the other to carry as reserve.
On the way up to N. Wales it stayed at 1. It was a gentle drive.
However, on the way back after the short and low(ish) speed cruise, I was equally startled to find it had gone back up to just below maximum and it has stayed there.
Can the indicator be relied upon, even if it says add oil?
I've seen plenty written on oil used, but, if the indicator itself is a bit random, even if you use it under identical conditions, how can you be sure of the actual oil level?
