So the missus got back today in her E85 Z4, handed me the keys, and said the red battery light was on. About 6pm.
I got in and no lights on other than parking brake, which went off when it was released.
However I noticed the middle interior light was left on.
I was busy decorating at the time, so decided to give it a quick run along the local dual carriageway to give it a quick boost.
So about 3 miles from home the dash lit up with yellow lights abs, tyre pressure, traction control. then the front camera display started flickering. I pulled off at the next slip road as things got progressively worse, parking brake light on, but now flashing yellow/red.
Then power steering went altogether!!!! followed by the headlights then the engine started missing. I struggled to just about get onto a nearby Wickes car park, with everything in darkness.
switched off and tried to restart but all dash lights dim and click from starter.
Called the missus and asked her to bring the spare battery and socket set.
When she arrived I swapped the battery over, and everything working perfectly again.
Put headlights on main beam, heater on and revved it , but I couldn' t make out the brightness of the lights increasing.
So I got home to the garage and put the meter on it. 12.4 volts with no engine on,
Started engine and dropped to 11.9v
Revved engine and no change. put lights on and voltsge dropped further to 11.4.
So no output from alternator.
Belt still on , alternator turning, no noises, just no output.
Can do without buying a new Bosch alternator at the moment at over £200, as just spent that on wallpapering and have a new car deposit to pay!
Has anyone solved this by just replacing the voltage regulator?
Otherwise options include:
New voltage regulator.
New cheap complete alternator.
Second hand genuine full alternator.
I went the second hand route with a starter motor and that has done 2 years without issue.
anyway, there I am on Wickes can park, freezing in just a short sleeved t-shirt, trying to swap a battery in the dark, when the missus said, oh yes the battery light was on yesterday it was yellow!!!!!
So, I could have just put a coat on, and got the meter out at home in the garage..!!
