Hi after buying my Z4 E85 2005, it came nearly fully loaded the only thing that it did not have is Cruise Control, so been in touch with the stealers and they have quoted the following:
Part Number: 61316940989-Cruise Control Stalk=£73.50+VAT
I intend to cut out the cowling to accept the stalk, rather than buy the cowling with the cut out already done (Which is over £100)
My Question's are: (Had them all answered Thank You)
1) Has anybody on here done this (Yes)
2) Any idea on how difficult to fit ( Easy Peesy 30 Minutes to fit including the cutting of the cowl) it turns out on mine to be plug and play as the wiring is already present, remove one screw remove cowling, cut cowling click stalk into place attach wiring re-assemble)
3) Are any other parts needed (No other Parts Needed)
4) Once done will the mod need to be set up in any way (No Plug and Play)
Seems a bit unclear if the mod will need configuring before you are able to use, some say that it works immediately without having it set up? (It does not need configuring)
