One of the more useful features on the Z4 is that they have cup holders (assuming the previous owner paid for them). They work really well, but they are a really bad internal design and I've joined the list of owners with a broken one. Not cheap to replace at around £60 each, and the new ones still have the same poor internal design anyway!
I took a photo today after stripping it down and found the plastic had split.
Thought I would try and resolve the issue with a cable tie, because cable ties fix pretty much everything!
However in this case, a cable tie didn't fix the issue. It's too thick as the small swinging arm needs to rest against the side wall. With it in place the floating arm which grabs the cup doesn't fit properly when retracted and jams the mechanism.
The next plan will be to remove the cable tie, then clean as much of the grease off the failed part and apply liberal amounts of plastic glue.
Will let you all know how it goes, for when yours goes!
