hi tony no its just the e85 is built on a e46 system & new e46 parts look the same & up to 1/3 the price of e85Are you wanting to use s/h parts?
hi thanks for that I've got some e46 dampers & physically they look the same I'm really after a softer ride and as e46 parts are so much the same as e85 & a lot cheaper & easy to change I'm going to give them a try the next thing that's bugging me is will there be a advantage to swapping my control arm bushes for offset z4m ones ?E46 front dampers work fine but you'll ideally need the M Sport versions. The Boge Super Touring units are perfect. The valving will be very slightly different but you're probably replacing high mileage worn out ones so....
