I have a Z3 2.8 year 2000.
I bought a ODB-scanner and got the ECU fault code "7B Activation, map cooling (ODBII
1622)".
When checking the ECU data stream I've noticed some weird values:
On a cold engine (>24h since running)
Starting the engine (idle)
Stopping the engine again
I can also stream some generic OBDII values which reads:
which to me seems more realistically.
My concern is the constant 81 on radiator outlet.
My guess is that it represents the sensor that looks like this:
I tried to disconnect the cable from the sensor but it still reads 81 in the scanner!
Does anyone have a clue and some suggestions how to proceed?
I guess I can try to find another sensor and connect it to the cable to see if I get some other readings...
| coolant temperature, engine [°C] | 83.32 |
| coolant temperature, radiator outlet[°C] | 81 |
| Oil temperature, engine[°C] | 104.80 |
| intake - air temperature[°C] | 73.95 |
| coolant temperature, engine [°C] | 87.38 |
| Oil temperature, engine[°C] | 103.93 |
| intake - air temperature[°C] | 74.23 |
| coolant temperature, engine [°C] | 143.68 |
| Oil temperature, engine[°C] | 110.02 |
| Engine coolant temperature | 46°C |
| Intake Air Temperature | 27°C |
