A few more jobs done.
Personally I think it's a case of " If you can't see it, it doesn't matter" And, you can't see it until you open the hood or the trunk !!. Never seen it on a European BMW only the US models.
Removed it today and cleaned it , it wants replacing really but will leave it on rather than risk any heat damage to the bonnet .
I never thought of it as heat protection but interesting you mention it, not had an issue and have it out for a few years now though.
They didn't paint the whole underside of the bonnet fully though so could do with coat of paint to look better.
Neither of my Z's have had under bonnet insulation.
Antm72
South Yorkshire
Yeah noticed that too ! It was nearly all painted but not all of it just a patch of primer in the middle! :mad:
5harp3y
its nothing to do with heat protection its there to reduce noise.
you'd have to get some serious heat into a bonnet to mess the paint up
Antm72
South Yorkshire
Not sure it will fit to be honest the rads fairly new and it measures short of 40 mm. Are you at Santa Pod sunday ?
andyglym
Been waiting on a set of sill guards to arrive from the states all the uk ones i have seen have been badly corroded due to our roads and salt.
Looked all over but found a set on ebay.com
There not perfect but 100 times better than what i had and for under half the cost of new im pleased.
Whilst fitting them gave the door openings a good clean not been done before but now spotless.
And after all these shiny engine bays of late decided i must get mine respectable.
Gave the power steering pipe a sanding and a lick of paint and degreased and cleaned it up.
Happy with the results the power steering cooler certainly looks better but wants removing really for full clean and power coat but crustyness has gone and it looks a little more respectable.:)
Looks bob on mate, the inside of my doors are a tad manky, I'll bring it round ;)
Antm72
South Yorkshire
Can you tell im looking for things to clean ..Next op on tuesday and then back to sofa surfing.
There only so many episodes of wheeler dealers one can watch =))=))
andyglym
Every little helps mate. Good luck with the Op and a speedy recovery. Oh, your bonnet catch could do with a clean and when you've finished, so does mine mate =))
Far too much tinkering time =))
No such thing.;) Had to fit a new O/S/F spring and top mount/bearing on Shirl's car yesterday, not half as much fun as doing all four on my car though.:)
Antm72
South Yorkshire
Not quite the same satisfaction in that hey @t-tony
You may be able to assist me in a few weeks with a full fluid change i could do it but i'll struggle getting it high enough off the ground...
I'd be happy to mate, whenever. I've got two trolley and some small stands so we could get all four corners up and level.
ps. New small project starts this weekend, if they arrive on time.
Antm72
South Yorkshire
Sounds interesting ! I'll finish geting all the fluids together that i'll need and then will sort something with you. Appreciate that :thankyou:
