Hi guys and girls,
Hope everyone’s having a great weekend, and those of us in the uk enjoying this AMAZING heatwave!
So I have a problem with my beautiful baby, a 2000 3.0 z3 roadster, and I’m looking for some help/advice/thoughts on this one!
To give a bit of context and background to the story....
I had my airbag light come in a month or so ago. It’s registering as the positive battery cable (SBK cable) and I’ve been so lucky in having the fantastic help and support of another member on here, @mrscalex , in tackling that. We are hopefully fitting a replacement soon. I’m only mentioning that because I don’t know if it bears any relevance/is linked to this new fault.
So the problem I’m seeking help on first occurred yesterday. I stared the car up for the second time in the day and my ABS and traction control lights were both on. My heart sank! This is not a new thing for me; I’ve had the standard wheel speed sensor faults and things like that before, and all those times I’ve the past a code has registered and I’ve gotten to the bottom of the problem and changed the sensor. Strangely though, no codes registered at all with these. I have a really good code reader (ex garage/mechanics one) that reads under the steering column and a cheaper one that I use to read the airbag codes from the engine. Neither registered any codes (other than the airbag one I know I have linked to the problem with the SBK cable)
The car was driving as normal. No crunching of ABS which I’ve had before when I had a fault with one of the wheel speed sensors. The lights both went off 5 mins into the drive.
This repeated on a drive later that day. Lights came on when I started the car up and went off after 5 mins. Again no codes.
Today I started up the car and heart sank as the dreaded 2 lights came on again. Once again no codes, but this time they stayed on for the full drive
I’ve asked a good friend and fellow zedder @Aceman and he’s leaning towards thinking it might be something to do with Mmm not sure but you are probably right in thinking the extremes heat at the moment may have something to do with the abs module as he says they do suffer from bad solder joints on the circuit board, which he explained you can either repair or replace the unit but that also involves recoding in the replacement which is a pain.
We thought it would be a good idea to put the question to the forum and ask if anyone else has any thoughts or ideas or indeed any of their own experiences of this?
Would it be worth taking it to a specialist bmw diagnostics place to see if they could read a bit deeper into the electronics? (I do have one up the road from me which is run by a couple of bmw master technicians who are good and have the software and know how for it, but do charge accordingly!!) or is it something I could potentially fix with the help of another member?
Thank you so much in advance everyone!!!!
