I’ve been progressing all the small parts. Some of these are expensive from BMW so I was determined to reuse what I could. The only fixing I’m replacing in the end is the ARB mounts as they are only about £3.50 ea.
The axle beam brackets are sprayed up now. Finish not perfect but the main thing is they are protected with several layers of paint now. Next time round I’ll get them blasted/powder-coated.
The rest has been going in the Deox in batches.
First through was a drop link bracket. £10 new from BMW but x2 = £20 and soon adds up.
Then the trailing arm bolts, here with a coat of Rustbuster FE-123.
Then the rest, here in 2 piles.
The nearest pile is plated in something that comes off as a black cloud in the Deox. And you get a film that dries off you can’t remove by washing. That includes the handbrake linkage/adjusters. No idea what that is. The bracket on the top is in the wrong pile. It holds the handbrake cable at the drop link. £10 for new ones of these with 2 required. Very easy to bend as they come off but they will straighten out.
The rest just cleans off normally. The large parts are the hub handbrake cable guides. These were in a nasty way.
The 2 piles will be going back in the Deox for one final dunking until Tue while I’m in Swansea. Then they’ll have the FE-123 and will be painted up in a range of different finishes to make them as factory matched as possible.
