Seat rebuild started today...... Got bits all over the house so it will be nice to get them reassembled
First job is to re-colour the damaged/worn parts of the leather covers.
This is the kit
And this is the repair needed.... drivers seat bolster
And where the belt guide had broken and the broken part had been rubbing
So read the instructions and the first job was to clean the leather......
Apparently there is someone on the forum that reckons this stuff is ok ....
Well it did clean the cover so then it was let it dry , mix up the colour and apply to the seat.... it took about 2 hours to build up the colour ...following the instructions.....but in the end not a bad result.
I managed to colour match my fingers as well
Have to leave it now for 24 hours then I can buff it with a bit of polish, and it hardens completely over the next 7 days.
Overall pretty happy with the result.
The heat pads fit ok ( or will do
) after a trim....
So only the electrical parts to sort....this is what you get....
The only bits used are on the left. The middle bits are worth keeping ( might be useful sometime) an the pile on the right is going in the bin
I removed the two way housings from both heat pad cables, did the same for the 4 way switch connector. The 4 heat pad crimps can now be assembled into the 4 way housing. The mating half has 4 wires (red, black, green and yellow). Which will be soldered to the wires in the car once I cut off the existing connector and work out a colour code ( and then match it on the other seat.
The only reason for doing this is to keep it tidy by only having one 4 way connector.
That was it for today.......
