Saturday was a nice trip up to see the guys at Zedshed HQ .....Only to pick up some parts that that had been cleaned up.
Didnt actually do anything......but then I suppose I never do
Also got loaded up with a lot of stuff for Andy, and dropped it off on my way home ( with a little bit of a detour )
But did pick up a replacement earth cable to replace a duff one.
And when I got home ...straight off to footy...so nothing done till today...
Early ( ish) start and sorted the earth cable first.
First re crimped one end as it looked a little bit loose, and thought it would be a good idea to add some heat shrink over the ends
All good and fixed it back on the car...
Except there is nothing to bolt the other end to yet.....
Then got on with a job I wasn't expecting.....I gave a front wing panel to a member so it could be sprayed and put on his car as a quick swap over, and his panel which didnt match the car would be returned to me .....no problem .....
Except ...mine was totally rust free and his wasn’t ......but c’est la vie
So a bit of cleaning, treating and priming gave me something to do ......
De rusted and treated
And a bit of the face side .....so all now treated and primed....
I picked up my LSD ( Limited Slip Differential) ...@Lee is not suppling me with drugs to keep me going !!!!
It had been shot blasted
Now primed and ready for top coat of black
I re-bled the brakes using a pressure system....and all seems to be ok ...no bubbles
So underneath and re assembled the spare wheel, (16in rim with a new tyre)
But still fits the tray albeit with a mod to add a spacer to stop it moving about.
The Old 16” wheels have been put back on for now as don’t want to mess the 17” ones up while still playing around with the car.
Then back onto the bumper as my new welding repair kit arrived while I was out on Saturday. Left by the back gate!!
But 3 days earlier than I was expecting it.
Basically a dual soldering iron with staples... ( 4 different types)
5 second heat up... push it in to the plastic ( on the inside
) and count to 10 and pull the iron away....
And this is the result....
I used four just to make sure.......Then snip off the tangs and apply a bit of filler and thats it.
While I had some filler I did go over the front lip as there were a few depressions
Doesn’t look to good at the moment,
, but will rub it all down tomorrow and see how it is.
But the main thing about today......was this !!!!
Back on its wheels.......Its been so long in the air I thought I might need to apply for a pilots licence
And best news of all the offside rear wheel now points in the right direction......
So enough for today and finish on a high .....
