Bognor Lean-to Project
Mazza
Bognor Regis
Such a tempting offer … but … as @GazHyde said yesterday at Zedshed HQ……”oh God Mazza’s all loved up” and I think he is right… so I’ll pass your offer xx =)) =)) =))
Mazzal
Has he (Mazza) also told you that he is now into fishing - both sea and freshwater- has set a challenge to us to see who is the first to catch all the UK’s freshwater fish. He is also a good coach steward - on our (Crawley) trip to Wembley recently his was the only one of 10 coaches who got lost and was heading for Birmingham on the M40 before realising that they were heading in the wrong direction at Beaconsfield.
Mazza
Bognor Regis
Finally it’s sitting in the sunshine on its 17” wheels
and adjusted the handbrake at the same time …it helps if it doesn’t roll out into the road :whistle:
just the roof and bonnet to swap over and it will be getting close to getting back on the road.
KASPar
Hampshire, near Z Shed HQ
Z3 2.8 M52 1998
Think you were a bit slow getting to post the image, someones nicked the wheels off the blue one in the background o_O :whistle: :thumbsup: :thumbsup:
rlane
RichL
Bishops Stortford, Hertfordshire
Z3 1.9
I like the "mad max" look @Mazza I'd leave it as it is :cool:
Who needs a roof?
........ it was nice meeting you on Sunday Malcolm.
Matt Barnes
Portchester, Fareham
@Matt Barnes
Matt, if you want to do some practice welding on it at any time you are welcome to come over and use it once the panels etc have been removed.
I don't know why I've only just clocked this! I was wading through your build adding bookmarks to mine !! 😆.. thank you mate, I do need to practice more but I've done my sills now..you have answered one question in that you used a vice for the trailing arm bushes, would a vice do for the beam and Diff bushes?.. I have a massive Woden vice and two smaller ones, so I'm hoping I can squeeze them in with a vice.
Mazza
Bognor Regis
I think Lee pushes the Diff bush in with a vice ???, but the beam bushes they use a press
Matt Barnes
thanks mate...thinking about it I would need a press for the beam as the beam sits in the middle of the bush
It's not what you use to press the Bush in, it's how far you press it. Easier with a Press though, more controllable.
Matt Barnes
thanks Tony..... I don't want the nightmare situation of cracking the Diff plate. Thought slowly winding in a big vice, plus it's got wood lined jaws. With the subframe bushes I've seen people use the "cup and pull" method, pulling the bush into a receptacle (like s bearing puller) and using a threaded bar. The upshot is , I don't have a press ! 😆 :whistle:
You could ask @Lee nicely if they could do it up at the Shed for you.
You might be closer to me Matt, I have a 20 ton press.
Guess not then Matt, in my head you're near Peterborough ;)
Mazza
Bognor Regis
Yesterday was about lowering the engine out of the donor car … The only company that will come and take it away specifies no fluids in the car and engine and gearbox out … but will take it away …. and all for free so had to work out a way to drop the engine in a controlled manor =))
@Lee did offer his engine hoist but I had a cunning plan …..:whistle::whistle:
it started with putting the engine support beam in place and getting a couple of extra shackles…
First thing was to support the engine and remove the support beam…
which decided to hang on to the engine mount … so hit it with a piece of wood and it fell off…. not going underneath at this stage !!!:eek:
really good condition and now for sale =))=))
Now on to dropping the lump!!
The only problem is that the screw thread on the supports were shorter than the distance I had to drop it …. but cunning plan would sort overcome that.
got a trolley jack and some wood etc and supported the gearbox…
bit heath robinson but it worked…
and undid the 4 bolts
lowered it down about half way and then began to do about five turns on each screw and it did start to drop … so all good, cunning plan working
then back underneath to lower the gearbox end
lowered it down to remove the jack… the tray is so I don’t damage the drive block work.
So back to the front….to continue lowering
Now came the awkward bit … I had to use a jack to support the engine, lengthen the chain and rewind the threaded bolts….. but it was at this stage I noticed some wiring was being stretched… so just cut it … easy option!!!
Continued to drop it until it was sitting on the floor …. then remove the wood from the gearbox and straightened it up on the tray and engine out and it didn’t fall on me … so a good result.
so today was about stripping the boot lid and doors , ( already sold ) just to leave the roof and bonnet which are the bits I need.
Didn’t take too long…to have boot and doors off…
then after a bit of spot weld drilling … slam plate was off
After that was removing engine bits that may be useful to someone .. put them on the for sale section after I have cleaned them.
Then final thing was to put a full cover over the shell …. not such an eyesore with a cover =))
Now just need a willing helper to get the bonnet and roof off……..
At least the sun was shining as it always does in Costa del Bognor =))
