central locking help..
swamper
Bacup
M
no............please look away for a minute while i swear X(
swamper
Bacup
M
update....phoned the indi and he reckons the immobilizer has been set off...as the car should start... said to ask auto sparky spoke to him and he reckons the key fob has lost its code or some such thing..............anyone know how to re-sync the integrated fob with the car?
update 2
re-sync...... it no work.....sparky cant get here for a week...............going playing in the M :coolsteer)
swamper
Bacup
M
fixed.......bloody brill.
for anyone reading this Robert has nailed it....but i had a slightly different stance as the battery was disconnected.
1st change battery in key fob and cycle through open/close buttons and resync it if not the follow the procedure in the above post.
if still not working open drivers door and put key into ignition to position 2 it should fire the door door locks and turn alarm off.
if that fails (which happened on mine) take battery terminal of in boot and wait till lower alarm stops beeping...put key in position 2 and reconnect the battery...it will fire the door pins and turn the alarm off.............ok before i finish go back to the battery in the boot and tighten them up...as you will have forgot to do this as you have just been doing a little dance of joy on the drive :ymdevil:
this fault could have been caused by 2 things.... one key fob battery .....two battery in boot !
check both before you start stripping the car.....doors that have a key barrel can be opened with key .....the ones with out a barrel cant before the the alarm is deactivated....do not strip the door and try and open it you are wasting your time (did that :)) )
thanks to all who participated in the quiz.....same time next week we will learn how 2 rebuild a gear box :ymhug:
Snoops
Red Rose Country
I'll pass thanks...... #:-s my other half kept asking why are you looking at all those photos and videos of locks and doors......... after all that effort I feel like I failed
swamper
Bacup
M
NO NO......it was all a learning curve and after your dogged determination i now know what im looking at and im going to removing them and giving the a refurb using graphite powder ;)
couldn't have done it without ya luv... :ymhug:
Snoops
Red Rose Country
Awww thanks.......... in that case the actuator has gone on my passenger door so I'll nip down and you can fix that too :p
swamper
Bacup
M
give me chance to do mine.... :p
