Changing brake fluid
Just to clear up any misunderstanding, putting a "prop" on the brake pedal does not, and isn't intended to, put any pressure in the braking system. It is simply there to place the pistons in the master cylinder in such a position that fluid cannot run from the resevoir and empty the system. That is all it does.
